MilitaryRestoration
- 1
- 0
- Vancouver/Yakima, Wa
Been working on the wheels and tires once or twice during the week due to fires in the state, interrupting my process, but today was first day off in a long time so set a goal and did almost get all them done. So thought i'd post a few pictures of the progress. Hopefully will have them balanced soon and on by mid aug hence National Show in Portland...
I first pressure washed all the tires and wheels with about 4000 psi taking most everything off
and then I hand sanded the wheels first with 150 grit and then back over it with 100 grit. Vacuumed all the sanding dust off of them and then rewashed them by hand. After they dried I wiped them down with lacquer thinner to get rid of any excess dust and to prep the surface. Then shot them with RustOlem industrial primer and then with 383 carc green. Turned out excellent in my opinion. I also made a stencil from cardboard to keep the paint from getting onto the tires, but still had little over spray. Will just use paint thinner and remove after paint on wheels harden.
What are peoples suggestion for balancing these bad boys? They are going on a M818 that will be on road quite a bit...
![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
