tucker79
- 0
- 16
- S FL. United States
Im thinking of installing a Profab or SCS Transfer-case in my M818 WW. Just installed 1600s and after going through 2 stock T cases on 395s I hate the idea of swapping in another unknown case.
Has anyone done it???
If you could pick any gear ratio what would it be to run comfortable RPMs at 50 to 60 MPH???GEARING AVAILABLE FROM 3.8 UNDERDRIVE TO 2.73 OVERDRIVE
Some benefits I see with running one of these cases is some come with a 2wd/ 4wd option. They use them in Monster, Mega, Mud, Racing, pulling trucks with 2000+ HP and many are running 2.5 and 5 ton Rockwells so yokes is not a problem and there darn near indestructible. Also they are more compact 9.5 in flange to flange and would allow for some different transmission options if wanted. Much lighter. They come with quick change gears so your not stuck with whatever gears you start with. Come in all different lengths of drop. They run 2 to 3k
Reading OPCOMS thread on the T138 to T1138 http://www.steelsoldiers.com/showthread.php?59654-M818-Transfer-Case-Upgrade-T-138-to-T-1138
Seems one of these aftermarket cases would be a great way to go with similar cost if not less and you can buy the mounting/ install plate n cut way down on fab work. Still would have to retube drivshafts to get the lenth rite but other than that looks good in my head.
http://www.scsgearbox.com/wp-content/uploads/2015/11/10.66-Drop-Case.pdf
I am not affiliated with any of these co.s Just trying to BEEF UP my M818 as much as I can.
Anyone see any downsides or issues that may arise????
