Well,I did half of it.I installed the extenders and winch.Pretty much simple other than the 300+LBs of winch.Just pull the bumper,Grill,and the lower rockguard/slats on the grill.Install the lower extenders loosely,then put the uppers on the side of the winch also loosely.Set the winch on top of the lower extenders.Put all the bolts in and put the bumper back on.Then the grill.Tightened everything.On the PTO,Install it with one gasket and check gear lash(don't ask,I never got this far).Add gaskets till the gear lash is correct.The PTO shifter attaches to the side of the MasterCylinder I think.Not a hard job.Just a back breaking job.
