- 1,651
- 1,665
- 113
- Nova Laboratories, WA
From what I'm seeing in the TM, it appears that the fuel line is 3/8.... Which is equivalent to about a AN-8 line. AN-6 would be 5/16 and AN-8 would be 7/16...
Would there be any issue going to an AN-10 line, which is 1/2"? It would seem the increase in diameter would be relatively negligible. The ports on my planned spin on replacement fuel filter housings are 7/8 UNF which is super simple to toss an AN-10 line onto......
The pump is metered, correct? So, I don't have to worry about the volume of the line and its size as a variable in the fuel delivery system? Doesn't the unused fuel return to tank anyway?
I want to settle on a standard, and redo all the fuel lines in that standard.
Plain rubber lines don't seem that great.
AN-10 lines that I'm looking at are PTFE.....with stainless mesh outer covering..
I'm hoping to add in an in-line fuel cutoff, and inline pre-filter...
Am I overthinking it with the AN-10? Should I just replace the hard line and the short rubber sections?
Anyone know off hand the total length of the fuel system, in feet?![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
