Upgrading to radials
rhyne6262
Boone, North c
I am thinking about upgrading an M35 with standard non-directional tires to a radials and singles on the rear. What components are need to convert the rear duals to singles and what tire and size is recommeneded without any lifting or rubbing?
Regards
Adam R.
M1075
Oklahoma City
:deadhorse:
There is quite a bit of info on this if you want to search for it. If not, I'll give you my input and opinions:
1. New rims and tires are the only components needed to convert to singles. You may need to flip the rear hubs, depending on what rims you decide to go with.
2. The smallest single tire I would use is 12R20. You can also use 14.5R20, but both of these are hard to find. Some run 11R20, but if you want those, just keep it duals. The biggest tire you can run is 46" such as the Michelin XML 395/85R20 or Michelin XL G20 Pilote 15.5/80R20.
BKubu
1,152
Gaithersburg, MD
I'll add a bit to James' (M1075) response. If you run a tire like a Michelin 1100X20 XL radial, you can use the standard deuce rims. This is what the NG does. I have never seen a freshly released singled out M35A2 with rims other than the standard deuce rims. I have a singled out M35A2 with these tires on it right now and owned another one previously. I am not sure why James said that you should not run these tires/rims (I am paraphrasing a bit). Perhaps, it has to do with weight carrying capacity? Maybe, James can elaborate a bit...
M1075
Oklahoma City
Others may like it, but my opinion is that stock rims on a deuce in single configuration look goofy. The rear track is very narrow, compared to the bed width. M135 rims look better, especially if you get a narrow pipeline bed such as Cranetruck. Otherwise, super singles call for new rims (M35A3 or custom).
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Kip, many people feel that the look of a deuce with duals on it is "what a deuce is supposed to look like". I personaly feel that way. I do understand that a singled out deuce will out perform a "dually"deuce(off road), but I like the looks of them with duals.
BKubu
1,152
Gaithersburg, MD
James, I agree that the rearview looks wimpy with the singles...kind of scrawny looking. With that said, I like the XL tread pattern much better than the NDTs so that offsets things. I would consider putting duals on it...but the XLs cost so much (and are tough to find).
M1075
Oklahoma City
You mean 14.5s though, right? I had that setup on my deuce and then sold the set to Readyman. He has one of the best looking deuces I have ever seen!
OD_Coyote
58
North Bend, WA
Right you are 14.5s. I hope to shoe my truck with 1100R20s and 14.5s someday.
