Upload issues
155mm
Chief and Indian
506
Guymon, OK
Not really related to this topic, but there's both. (Size and timeout) There's a size limit invoked due to the hosting company. Then there's a timeout feature for safety reason. The timeout is there because if a user tried to upload something and lost connection, a process would remain running. If someone was using a cell connection or some other "unreliable" means, you could see where this becomes an issue. Basically spawning multiple processes and bringing the server to a crawl. Anyhow, what size was the file? The problem with the timeout is that everyone has different internet connection speeds. So there's not a "good" number I can set the timeout to accommodate everyone.
This is my problem also, unable to upload any photos or TM's. The photo problem just started today. Have tried using INSERT IMAGE and also the ATTACHMENT ICON, neither work.
Keeps saying UPLOAD OF FILE FAILED
Attempted using Opera, says the same thing, upload failed.
5,184
Moved this discussion to it's own thread since it's not related to the spacing issue.
For both of you, I need to know a few things.
1. OS
2. Browser
3. Internet connection and UPLOAD speed (not download)
4. Filesize
And here's a test of me uploading a picture from a slow ATT DSL connection. (Win 10, FF 51.0.1)
5,184
Ahh I think I know what the issue is. I upgraded PHP the other night, but it reverted its settings back to 2mb limit. I'll updated it back tonight when things are slow. (Requires a bounce of the webserver)
155mm
Chief and Indian
506
Guymon, OK
ok, i will crop the photo and see if that helps also to get it under 2mb
5,184
Yeah, it's hitting a brick wall due to PHP's "out of the box" settings. I had to upgrade it last night to get a new adserver running for some of the ads (still working on that). But I didn't even think about some of the default values resetting.
155mm
Chief and Indian
506
Guymon, OK
the biggest part about computers is 'knowing' so now i know my photos have to be less that 2mb. thank you much
juanprado
3,204
Metairie/La (N'awlins)
win 10
FF 51.0.1
11.42 up
cox cable
pic was 2.28mb
tm upload 19.5mb
Last Result:
Download Speed: 91153 kbps (11394.1 KB/sec transfer rate)
Upload Speed: 11417 kbps (1427.1 KB/sec transfer rate)
Latency: 82 ms
Jitter: 3 ms
1/30/2017, 10:16:09 PM
