CCATLETT1984
- 5
- 0
- Saint Clair Shores, MI
My 6.2 is really hard to start cold, I have to spray with wd-40 ( glow plugs are disconnected) to start. after it warms up, it will start on the first crank for several hours. I just finished replacing the lift pump, thought that the problem was a worn out check valve allowing fuel to drain back into the tank, but still having the same problem.
