US Shift Controller Install Questions
dodgemain
Sterling Heights, MI
Hi,
I have been working on installing a 4L80E in my M998. Almost to the point where I can start installing the controller I got from US Shift. If anyone has any installation tips they would be great appreciated. My main question is how/where do I connect the Power Wire? In the manual it says "ignition-switched power wire." How does that apply to a HMMWV? The truck does have a 200 Amp generator. Has anyone found where to connect the tach wire? Also, can I start the engine without the controller connected? Want to start to fill the trans with fluid.
richingalveston
120
galveston/Texas
I do not know about tack interface on hummer, The cucv requires a dakata digital ds1 controller to change the alt signal to a usable tach signal. not sure you can do this on a hummer.
yes you can start the engine, It just wont shift right without the controller
you may have to install a switch so the controller does not stay on and drain the battery. controller only needs to be on when engine running thus it normally connects to the ignition circuit.
In a hummer you may have to turn it on manually with a switch.
I have one installed in 1009 not hummer but was easy to install. You will also need throttle position sensor which goes on IP if you don't already have that.
Rich
ari
dacula Ga
maby tap off of a power wire behind the instrument cluster since those turn on with the ignition so will your us shift.
Barrman
1,725
Giddings, Texas
I am pretty sure the controller needs a constant 12 volt supply as well to keep its settings.
The computer will also need a throttle position sensor signal to know when to shift gears.
A 4L80E has 2 solenoids that control the 4 gears. Another solenoid controls the torque converter clutch lock up. Both solenoids off is 2nd gear. So, if all you have is second and reverse. then something isn't hook up correctly. I have discovered that it is ok to drive the vehicle with the main transmission plug unplugged. Just in case you need to move it before everything is done.
ari
dacula Ga
I have a question did you use us shift TPS that they supply or did you go another route? if you did use theirs can you post a pic of it installed? I have been thinking about using their set up if I upgrade to a 4l80e
snowtrac nome
137
western alaska
I remember the keep alive power went to the 12 volt positive post on the 1114's never had to trace out the ignition power it would also have to be 12 volt. a simple way to do it would be a voltage converter but a 24 volt coil relay with 12 volt switched power could do the same thing just think reverse of the cucv relay under the steering collumn
richingalveston
120
galveston/Texas
yes there is a constant power they recommend going directly to battery and one that needs to be switched for the controller.
The TPS goes on the side of the IP where the vacuum switch goes. you no longer need the vacuum switch. In fact you no longer need the vacuum pump once you get rid of th400
I don't know where to get tach signal from hummer.
dodgemain
Hi,
I was able to use a OEM throttle position sensor. The part number is AC Delco 213-879. After removing the plastic cam and kick down switch the TPS was a simple bolt on. I added the military Packard wire connectors.
dodgemain
Hi, I have been working on installing a 4L80E in my M998. Almost to the point where I can start installing the controller I got from US Shift. If anyone has any installation tips they would be great appreciated. My main question is how/where do I connect the Power Wire? In the manual it says "ignition-switched power wire." How does that apply to a HMMWV? The truck does have a 200 Amp generator. Thanks
Hi,
Ended up following the wiring diagram in the manual. Once a guy I work with explained it to me it was very easy. Purchased a 24 volt relay and mounted it in the battery compartment.
