Used Fry Oil, WVO
jpekarek
10
Vancouver, WA.
I have an opportunity to buy up to 1000 gallons of UVO for $250. That's .25 per gallon.
Question 1) Is this a good deal?
Question 2) What should I look for?
Question 3) What would make it unusable?
Thanks in advance!
James.
1,540
62
Riyadh, Saudi Arabia
FILTER FILTER FILTER. A centrifuge is best. Also use a water separator. The Deuce will burn just about anything but it cant stand water in the mix. Thin it out with gas or diesel. Keep an extra set of fuel filters with you.
jpekarek
10
Vancouver, WA.
Im just a little torn on what works best. Veggi oil ormotor oil? I know there is a lot of info here and I have read it all. But what are the preferences? Will I have problems with veggi oil in the winter? I want a fuel I can dispense into the tank and forget about it for a while.
1,540
62
Veggie oil will have to be kept warm, do a forum search this has been discussed in great detail. Some use WVO year round they just thin it more in the winter. Or you could go to a two tank system. Put a heater for the WVO tank and start and stop on diesel so you dont have to worry about gelling the fuel filters or injectors in the cold.
Also I believe WVO has less BTU's then WMO or Diesel. So you might experience a slight loss in power or an increased consumption of fuel.
jpekarek
10
Vancouver, WA.
Well I just stopped by a little repair garage 2 blocks from my work. They have a 400 gallon waste oil tank out back. The owner said I can come by and pump a barrel of oil out anytime I want! FREE FUEL!! :D
1,540
62
Getting the WVO and turning it into Bio-diesel is the best option. Biodiesel can be used in the winter with little problem. If you go the biodiesel route I would still mix it with straight diesel and some diesel bio-cide Just to eliminate any concerns.
wreckerman893
Possum Connoisseur
15,617
2,010
Since you now have a source for WVO and UMO you can use my formula for Wreckerman's Special Deuce Elixer.
For a 100 gallon batch use: 30 gal WMO, 30 gal WVO, 30 gal straight diesel and 10 gals reg gas.
In the winter you can back off the WVO and add 10 more gals of gas.
In sub zero you can eliminate the WVO and just use WMO and gas. Adding a diesel conditioner will help prevent jelling if it is REAL cold.
When you pump out of the WMO tank start at the top.....never, ever, put your pickup tube into the bottom....that is where all the crud and water settle.
I have a filter on my pump setup.....I highly reccommed that....I use it to move liquids around and to fuel my trucks....my stuff gets filtered at every step of the process.
Your milage may vary.
2,413
Substitutions
You may also substitute 10 gallons of paint thinner for the gasoline, but be sure you install an "air intake blockoff system" prior to cranking the engine.
:-D:driver::grd::shock::twisted:
area52
San Bernardino CA
Where does the possum grease come in at? :p
