Usmc m1030b1
Bradyrw625
88
Texas
I just bought two M1030B1's. One is a bit of a parts bike. My buddy and I split the total cost and he will get the better of the two bikes. I just need to find a black out light and switch. My bike is missing it but the other one has it. We are going to tear them down and restore them. I'm going with a desert tan paint job with CARC paint.image.jpgimage.jpgimage.jpgimage.jpg
maetl
Bend, OR
Does anyone have any TM's for these bikes?
I've emailed F1 Engineering and Hayes, awaiting response to see if they have any.
I've searched SS and the Internet in general and can't find a thing.
Bradyrw625
88
Texas
Bikes in!
Got the bikes in today. They are both manufactured in June 1999 and the VIN states 2000 along with the USMC data plate. We started stripping them down. The plan is to sand blast and then powder coat the frame prior to painting everything in CARC tan.
MWMULES
345
DESOTO, KANSAS
Nice, most of the bikes I have run across are dated that way also. The rare parts are the small part of the wiring harness in the "Net" loom along with the small rear skid plate, F1 mono shock, nerf bar, front & rear BO light, BO light switch, fuel tank. You are lucky on the goggle/tool bag being there on both bikes.
Bradyrw625
88
Texas
I'm missing both gas tank caps. I'm having a tough time finding those. Any ideas?if I can't find those I will have to switch to the M1030M1 IMS tank with the cutouts. I'm also missing one front black out light and one nerf bar. Other then that the wiring looks good, the rear blackout lights are there, and the black out switches are there. Do you have a picture of the small rear skid plate? I'm not sure what that part looks like. We did luck out with the front tool bag.
Bradyrw625
88
Texas
More progress
Almost got it all the way down to the frame. We are working on the "parts bike" now. Originally two were purchased with one being a "parts bike". We plan on getting both up and running. I found out that the rear skid plate is missing on one but we can get a fab shop to copy the one on the "good bike".
Bradyrw625
88
Texas
UPDATE 8 October
Most of the bolts are rusted on so the last few have been tough. I still haven't gotten the handle bars or swing arm off yet. I'm letting PB Blaster soak in overnight. It looks like the rear shock was a progressive 500/560. I know the newer version had the F1 engineering shock. I also ordered the stainless steel screw kit from Desmoparts. I will be replacing a few parts on the bike. I'm also going to use RAPCO 686 Tan. It's spot on for CARC. For the frame, bars, forks, and swing arm I'll sand blast and powder coat prior to painting.
Bradyrw625
88
Texas
Got it down to just the frame and swingarm. Everything was rusted on. It took some MacGyver skills to get the handle bars and triple trees off. Anyone have any tips to get the "dog bones" off the swingarm? I should have done it when the rearend was together. now it's much tougher to get any leverage on them. I'll have some free time later this week to hit it again. Then the frame is off to sand blast and powder coat. The other bike remains untouched but the frame appears to be recently CARC'd. My buddy is going to keep that one green and I'll go for tan.
Bradyrw625
88
Texas
Finally got the dog bones off with a air impact gun. I'm still having trouble with the pivot bolt. I removed the nut but the pivot bolt isn't coming out. I even used a pipe and hammer trying to bang it out. Any one have any ideas?
We also blasted off some of the handlebars. This USMC handlebars has mounts for the brush guard. The welds still look great. Until we can get the pivot bolt out we are moving on to the other bike. This one is in much better shape. It won't need to be stripped to the frame. Hopefully we can get it up and running an then move to paint.
Bradyrw625
88
Texas
While waiting on the multiple penetrating lube products to take effect on the pivot bolt I decided to paint my helmet. The original USMC helmet was a matte green Winex SR-X. They are a bit hard to find so I found a FOX V1 helmet on sale for $118 shipped. Unfortunately its neon green and blue. During the invasion most of the vehicles were green or woodland camo. The field expedient method was to just rattle can everything tan. I went ahead and used RAPCO 686 Tan. First I sanded down the original paint. Then I sprayed with RAPCO primer. Then a few coats of RAPCO tan. Finally I used a matte black to stencil on a few things.
Bradyrw625
88
Texas
Still haven’t had the time to try removing the pivot bolt. The next option is till the brass drift, handheld sledge, Kroil, and the air impact. If that doesn't work we will cut it out.
We also found 6 M1030B1’s being auctioned by a sheriff’s department. I believe they received them under the LE program from the military. We threw out a reasonable bid and won! Not sure if we are going to part them out, sell them or restore a few to sell. Now we just need to work on getting them to Oregon.
dougco1
582
Cooperstown NY
Got the bikes in today. They are both manufactured in June 1999 and the VIN states 2000 along with the USMC data plate. We started stripping them down. The plan is to sand blast and then powder coat the frame prior to painting everything tan.
Are all your next door neighbors running to your homeowners association yet? I bet you gained a lot of (what is he up to now) and (I wonder if he's going to ride those at 2 in the morning)
Bradyrw625
88
Texas
Two of the bikes are at my buddies house and the other 6 are in storage. He's already getting strange looks when we were working on them in the driveway. I just avoid my neighbors.
Bradyrw625
88
Texas
One of the bikes is being restored right now. Since my buddy is handling it I don't have any progress pictures yet. It's mostly just been chain, sprockets, carb rebuild, etc. Mostly the boring stuff. I did get the DD Form 1348 that released these bikes from Hayes Diversified Technologies to the Marine Corps. It's lists the price at $6,518. I'm not sure if that was the total cost or just for the extra work and parts installed. I know the diesel conversion was a much higher price.
Bradyrw625
88
Texas
I'm finally leaving Iraq and heading home in April. The build will start again to include the 6 auction bikes as well. I plan on getting my bike and at least one auction bike finished in a month. I'll post the updates here as I go. It's going to be a good amount of work.
