- 410
- 34
- 28
- Atlanta, Ga
I painted several parts with Gillispie 24052 USMC Semi-Glass OD I purchased from Rapco. The issue I'm having is that is has a fairly high level of gloss even after about 5-6 hours of painting. Will this fade down? The reason I ask is that I painted over a small section of a freshly painted jerry can (painted this afternoon with 24052) and the spray can from Rapco of 24052 was much less glossy. Am I doing something wrong or should I give it a few days at 85 degrees or so. TO give a little prep history, it was blasted and primered with two coats of 2 part epoxy primer (3 hour apart) and let sit for 48 hours in my garage wich is in the low 80s.
Please help as I don't want to have to go over every piece after I spray it with the gun with a raddle can to get the right color.
Jason
Jason
