Vacuum tubing routing behind the dash
Johan1963
Minnesota
I've been through the manuals, but I can't find any information about how the vacuum tubing is routed behind the dash? Is it a rubber hose, steel line or both from where it comes through the firewall over to the windshield hollow bolt?
John
G744
4,121
Hidden Valley, Az
Rubber hose from the windshield bolt, then thru the double rubber grommet with the speedo cable (If I remember rightly).
Redleg130
188
33
Kansas
Ill grab pictures of mine under the dash when I have daylight since its cleared out, but it does enter from the engine compartment as G744 says, next to the speedometer cable, at least on mine
Johan1963
Minnesota
Thanks I would really appreciate it. I'm also interested how it was attached to the firewall, how many clamps and where. Mine was already torn out when I bought it.
John
ODAddict
309
Charlottesville, VA
If I understand what your asking, it's the windshield wiper hose running from the metal line attached to the fuel pump. The line enters the firewall and crosses along the inside of the firewall (supported by clips attached to the firewall) and attaches to the windshield wiper hinge tube which goes through the left windshield pillar.
According to the ORD 9, pg 427 Part No. CC-1271729, it's a rubber hose OD 7/16, ID 7/32 (same as other wiper hoses) and 55 inches long.
Hope that helps.
John
ODAddict
309
Charlottesville, VA
Here are a few photos that may help. The photos attached are in order starting with the outside firewall. As Redleg130 indicated, the vacuum line runs through a grommet to the inside of the firewall.
The other photos show the black hose vacuum line running from right (where the line enters the firewall) to the left side where the hose attaches to the metal tube running through the windshield pivot. As you may note, before disassembly the line in my truck was just kinda floating around where it was routed over various other cables and wires. Likely it had been replaced at some time since factory delivery.
There's a lot going on in the photos, but once you see the line entering the dash area, you should be able to follow it.
Redleg130
188
33
Kansas
grabbed some photos, ODAddicts are good illustrations but ill include mine as well.
Entrance of vacuum line behind air cleaner
Other side of the above, just inside the dash area, behind the glove box
the rubber line runs along the back of the dash on the firewall from passenger side to drivers side
On drivers side, it exits out metal line
and metal line comes out by the rear view and is connected to rubber line
then back in and around to the drivers wiper motor
and from there to the passenger motor
ODAddict
309
Charlottesville, VA
Good photos, and the more, the better. I'm in the process of building up my cab after a total teardown.
I don't believe there is a stock routing diagram available, either for the vacuum system or the wiring behind the dash. These additional photos go a long way toward creating one. It seems that Redleg130's wiper vacuum line routing is nearly identical to mine. Thank you.
Johan1963
Minnesota
Thats what I was looking for. Thanks, I really appreciate it. it also shows me where the harness is clamped. I failed to take pictures when I tore mine apart.
Thanks,
John
