Valve Needed
swbradley1
Modertator
1,828
Dayton, OH
Does anyone know where I can get this valve?
2530-00-753-3853
MS500046-1
VALVE:AIR SUPPLY ASSEMBLY
The TM says it is the right one (I hope).
It's the one under the dash on the right hand side for aux air and I have one leaking and it has some corrosion on it.
thx
steve
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
Mine was stubborn and leaking, was able to take it apart, clean, and it works now. If not, plenty of people scraping deuces out should have one.
Dennis
m16ty
218
Dickson,TN
Just hauled one off with what was left of a truck yesterday to the scrap yard.
Gimpyrobb is parting a truck. I bet he's got one.
1,818
Steve, you can screw on a quick coupler unless it's leaking from the valve handle. They are somewhat fixable.
swbradley1
Modertator
1,828
Dayton, OH
Thanks to all who responded. I;m going to try and get one AND rebuild the one that is in it for a spare.
steve
mudguppy
15
duncan, sc
so i actually used this valve the other weekend and now it is leaking like a sieve from the valve handle (both sides).
did anyone find a source for this valve?
if not, does anyone have one in good operable (i.e. air tight) condition?
or has anyone found a suitable alternative?
hoop
14
va
A gas valve will not have the relief port on it.
I would use a ball valve and adapt the configuration of the handle.
But then a most ball valves do not have a relief either.
Crawdaddy
Louisiana
Not to threadjack or anything, but with that valve, would you hook up an air hose connector to the side port sticking straight into the cab, or the port opposite the incoming air line pointing to the passenger side of the cab?
mudguppy
15
duncan, sc
this will sound like an incredibly stoopid question, but why would i need a relief port at this valve? i haven't taken it off, but thought it was just a ball valve.
i have blow-off valves on my tank - what value is a relief port at this valve?
