valve replacement
NDT
6,253
Camp Wood/LC, TX
Drain oil and coolant, remove manifolds, remove injectors, remove valve covers, remove rocker assemblies and push rods, remove heads (need special wrench), compress valve springs (special tool), remove keepers, remove valves. The naturally aspirated engine is a LD465.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
You forgot, posr a bunch of pics!
If valves need replaced, I'm sure theres more to it. I have some take out valves if you need any.
