yertnamreg
- 21
- 8
- Houston TX
I'm in the process of doing a tire change on my M1085. I've taken the easy way out and taken it to a tire shop ![Banana :naner: :naner:](https://www.steelsoldiers.com/images/smilies/banana.gif)
We've only done one tire so far because we're waiting on o-rings, but the results were less than stellar. The morning after the tire change the tire was flat. To make sure this doesn't happen on the rest of the tires, I'm buying all new seals for the CTIS assembly on the wheels. I've been able to find everything at finditparts EXCEPT for the valve stem seal that sits between the turret and rim. I even called Dill (the mfg) and they stated its an obsolete and unsupported part.
Soooo, my question is:
Where can I buy just the seal for the valve stem? Seems a little ridiculous we should have to buy a whole new stem assembly when most times its just the seal that needs replaced.
