Valve stems
Smike740
15
Columbus, Ohio
Standard valve cores will fit in the existing valve stems, however you will have trouble with finding any valve stem caps that will fit due to the unique end shape. If you want to change valve stems the MRAP one will fit however they are large bore you can use them as is or install small bore adapters.
