Valves rattling on a 6.2?
cjkeeliii
Thomasville, GA
When I accelerate, I hear a rattling that sounds like that which comes from a gasoline engine with low octane fuel. Is this normal and do some diesel fuels have a lower octane, (or is it cetane)? I'm not sure if this is a new sound, maybe its been there all along. The engine has approximately 63,000 miles.
acetomatoco
Cucv engines make all kinds of funny noises...most all related to the compression ignition of the fuel. Mechanical noises will usually manifest themselves in a skip or a smoke or a catastrophic failure.
cjkeeliii
Thomasville, GA
The oil change is on schedule, but what's the timing set? I should have asked how is the timing set? I used some ehter the other night to start the engine and it revved really high. Now I'm wondering if the rattling has always been there or if I've damaged somehting. What are the damages that could be done when using ehter?
Croatan_Kid
New Bern, NC
I was talking about the crank gear, cam gear and chain, just like a small block Chevy. I think the noise is just the timing chain because this also drives the injector pump which is sometimes subjected to pretty high temperature spikes. When that happens the slack in the chain makes a pretty good racket. I'm sure somebody else could explain that a little better though.
ida34
32
Dexter, MI
Are your glow plugs working at all? If they are do not use ether. Disable the glow plug system before attempting to start with ether.
acetomatoco
Good batteries cure most of the cold weather starting problems..long fast cranking does the job. Since I put a 12V starter in my CUCV and run it on 24V it really cranks over on two brandy new 1000CCA group 31s. Just remember not to crank too long or you will see liquid solder running out of the poor starter...My flex plate has a low spot in it, so at some point I will have to pull the tranny and then put in the rebuilt 24V starter and maybe even the front seal in the xfer case which in cold weather leaves little red circles in the snow. Be careful with the ether..!!!
cjkeeliii
Thomasville, GA
I've been listening to this new rattling as I drive to and from work. I'm fairly certain that it is new. My dilema started the other day when, after I cranked the engine, it slowed RPM's a couple of times and then quit. The tank had enough fuel but something had stopped the fuel flow. At any rate, the engine was cold and when I have used ether in the past, the engine has been at operating temperature. This time, I disconnected the GP's and used ether but it would not crank after several tries. I reconnected the GP's,( because I thought that the ether had passed from the system), and cranked the engine which resulted in extremely high RPM's for about 1/4 second and then I shut it down. That happened twice before it cranked and ran at normal RPM. The rattling comes and goes, so unless someone can tell me if I need to park the vehicle and have it looked at, I'm going to drive the thing and hope for the best.
KD
Central Indiana
6.2 rattling noise
Hi CJ
Have you changed the fuel filter lately? This engine seems pretty finiky on that item. Plus it is a relatively cheap and easy cure to alot of starting and running issues I have seen on the CUCVs.
Good luck,
KD
underdog
Sunbright,TN
6.2 is all gear drive. No chain.
Depending on vehicle and weather they make all kinds of racket.
underdog
Sunbright,TN
Had one of ours apart.
Water pump change is just loads of fun.
Guess i needed to dig deeper to find a chain.
My bad.......
Could of swore i searched for a chain to check on while i was in there.
Oh well.
CCATLETT1984
Saint Clair Shores, MI
underdog, FYI the factory setup has a chain driving the IP, you can however buy an aftermarket gear-set to replace the chain.
To see the chain you have to pull the front cover off of the engine, you prolly didnt have that off when you removed the water pump, as you would have had to pull the crank pully and damper off.
