Vent replacement
ida34
33
Dexter, MI
Remove the trim. Remove the crank up window. Then remove the vent window. You have to twist the vent window around as the front frame for the crankup window is attached to it. Pull the window out through the window opening at the top of the door.
SPECIALTYLC
Washington
You dont have to remove the crank up window, just remove the bolt for the front track. Remove the window guides and the atatching screws for the vent frame.
ida34
33
Dexter, MI
I would rather remove the window so you do not accidently damage it while twisting the vent window frame around to get it out. Do what you want.
