vibration at 55mph in m1008
rfischba1
Fort Meade MD
Yes , the vibration/noise get louder, as soon as I slow back to 45mph it stops. Its more noise than vibration like its the tire.
Maybe out of alignment?
galeo7171
Cumming, Ga
When I picked up my 1009 three weeks ago it would vibrate around 55-65 mph. I took it to the local tire place and every tire was dry rotted. I had them put 4 new tires on (BF all terrain) and the vibration went away.
steelsoldiers
3,971
Charleston, WV
Double check that your hubs are unlocked. I had that happen one time. I had one hub locked. I think someone was screwing with me.
How are your tires? New? Worn? Stock size?
Does the vibration/noise seem louder in a turn? Could be a wheel bearing then. Jack the front end up and see if you have any side-to-side play with either wheel.
rfischba1
Fort Meade MD
Tires are the coopers and have very good tread, wheel bearings were repacked and front end checked out ok. its more of a vibration noise that gets louder when I hit 50 in the M1008.
Tires not new , but not rotted. May be I will have the tire shop take a look.
jag7720
Kansas City, MO
The bands in the tires can be broken and can cause vibration and steering issues. Even if they have good tread and are not rotted they can break. Especially if they are old.
Does it go away after you get past 50 or 60 mph?
rfischba1
Fort Meade MD
Have not tried to push it past 55 once the noise starte, I did have one hub locked in, set it to free, still has noise and some vibration, could be old tires even though they have excellent tread. Mow about a wheel out of balance?
Next stop will be a tire shop just to make sure they are not about to blow out.
tsmall07
Springfield, VA
You shouldn't be going past 55 anyway, really. I think you're getting a noise because you're at the upper end of the rpm range for the motor.
B3.3T
92
SW Ohio
Without knowing more, don't forget to check your drive shaft. Could be out of balance or a bad universal.
