Vibration in driveline
nspctr1
San Antonio TX
When backing up the 998 and I apply the brakes, I get a strong vibration. feels like it is coming from the rear disc but not sure. It doesn't do it while going forward which seems kind of weird to me. Is it normal? How can I diagnose it, fix it? It's a 1992 with the 6.2 in case that matters.
Bulldogger
585
Quantico VA
It could be a lot of things without more information. But I would check to see if one of your hubs maybe loose. Jack her up at each tire and see if there is any play. At the same time you can rotate the tire and see if there is too much play in the jack shaft.
Bulldogger
86humv
501
Texas
There are brackets that hold your diff on the side.....the big bolts back out sometime.
