Vibration issue
TXGunner
Houston
Hey folks. 1993 m998 6.2 liter three speed has developed an engine vibration between 50 and 55 mph. Runs smooth outside of that range. I don’t have a Tac so not sure of the rpm but it does it out of gear also if you rev it up. When checking the motor mounts I noticed an engine oil leak now where there was none before. Am I doomed or has anyone else run into this?
rcamacho
825
Bainbridge Island Wa
Tire balance?
Driveshaft u-joint wear/impending failure?
I recently replaced all u joints and carrier bearing on my M998. Carrier bearing was worn. One u joint was brinneled dry and going to fail. Several others were worn/loose.
TXGunner
Houston
Were you trying to say that it vibrates at a particular rpm range, no matter if moving or sitting still? Your hmmwv doesn’t have Park.
Yes. When the transmission is in neutral and engine at higher RPM the vibration is there but only at a certain range then it goes away. Or at 50-50 mph. Same RPM range. It’s in the engine, not the drivetrain.
cwc
152
Sweeden, KY
I recently had a vibration with a 6.5 in a M1045A2 and the outer ring on the harmonic balancer was visibly wobbling. Take a look with it running and see if it's running true. You might see also that the rubber is degraded. Not hard to replace...
I also had another 6.5 with a vibration like you describe; that one had loose torque converter bolts.
Sent from my E6910 using Tapatalk
TOBASH
3,397
Brooklyn, NY
Harmonic balancers supposedly break free of their woodruff keys and can loosen on the 6.2 engines. I would immediately stop driving and check! If that is the problem, replace the harmonic and re-install with updated longer bolt to secure it.
Mogman
9,211
Papalote, TX
I agree with the rest, sounds like a loose/defective harmonic balancer
TXGunner
Houston
I rinsed down the engine and ran at idle. The balanCer definitely has a slight wobble to it. Now all I have to do is locate one and a seal. Thank you all for the help.
  • Like
Reactions: cwc
TOM R
91
sewell n.j.
i have a vibration thats intermittant comes and goes from say 35 mph and up, sometimes it shakes the truck horribly, ive moved tires around with no change, checked front end, serviced the outer hubs and all fluids, checked torque on the cv bolts and checked ujoints, 1992 6.5 na
TOBASH
3,397
Brooklyn, NY
Tom, did you read through this thread?
TOM R
91
sewell n.j.
Yes, and I believe I checked the damper before, but can check again , I do know one of my low speed shakes is flat spot in at least one tire that goes away after a mile or so, I have 12 bolt rims with the wrangler m/t tires and run flats in them
I just ran an errand and did run the rpm up in neutral without and odd shake or vibration
TOBASH
3,397
Brooklyn, NY
Have you tried Centrimatics and checking your alignment?
TOM R
91
sewell n.j.
I know my alignment was off significantly but adding the winch,luverne bg , sup armored x doors and armored grills seems to have brought the front back down and fixed the camber and toe, though I can check the toe once snows gone
TOBASH
3,397
Brooklyn, NY
Alignment can easily cause speed related vibrations. So can unbalanced wheels OR wheels dirty with hidden deposits of snow/ice/mud.
TOM R
91
sewell n.j.
I don't off road this vehicle and it does it in nice weather too, I could see a tire balance issue but this comes and goes , say I hit 50mph on speedo, truck may shake bad like I have a flat I slow down some and speed back up ,gone or very minimal
I have serviced the outer hubs and checked the torque on the cv bolt in port holes but I did not pull the inspection plates and check that nut that holds the wheel hub on, it did appear they were previously apart
