Volt gauge help
MarcusOReallyus
818
Virginia
There could be many issues. It's really hard to help you with so little information. Best thing at this point is to download the TMs and start reading.
Do you have a voltmeter so you can do some testing?
Warthog
236
OKC, OK
Check the very bottom fuse.
check for voltage at the back of the voltmeter
check the resistor on the back of the meter. Should be ~300 ohms
1,183
Has it ever worked?
Is the relay in place?
1,183
I'd say fuse or relay.
Should be a troubleshooting section in the -20.
