Volt Meter Connections for Rosscommon Conversion Single Alt.
Brogman
Noblesville, Indiana
I have a new 12volt volt meter. Tried using the original connections after the rosscommon conversion. Doesn't work no power to the Gray wire. Would like to get this working properly. Can anyone help?
Brogman
Thanks rsh4364 said with a laugh. I was hoping to install it to the original wiring connections. Already have the light working using the original wires. Do you have a suggestion for a + that is only active with the key on? I could use one of those splice connectors and run a wire from it to the meter.
1,178
Have you looked at the TM for the schematics?
cucvrus
10,427
Jonestown Pennsylvania
Check out the fuse box. It has a couple of open areas that are switched off and on with the key. Use an in line fuse and it will give you a switched power source. I hope that helps.
Warthog
232
OKC, OK
The CUCV Helpful Threads sticky has a thread for the diagram of the fusebox. It tells you what connection is controlled by what.
Brogman
Thank you gentleman. Is there a reason that the original wiring won't work. I know it was set up for 24 volts so I assume there is something there that might cause it not to work.
Warthog
232
OKC, OK
Was the gauge working before?
if the conversion is done properly the 24v which feeds the voltmeter (through the voltmeter relay) should now be feeding 12v to the meter plug.
Brogman
Thank you Warthog. The meter was dead. I thought it might be the meter and not the wiring. I thought there may be a reason the new meter wouldn't work due to diodes or something for the 24 volt system. You answered that question. I will "try" to figure out the wiring diagram and hopefully fix the stock wiring if not will try something else. I need to figure out which relay is the volt meters and see if that is the problem. My Gen 2 light works so will get a relay and then unplug each relay to see which one powers the gen 2 and that would tell me which one is the volt meter relay. With the key off while plugging and unplugging.
Warthog
232
OKC, OK
The voltmeter relay will have the white, black and pink/black wires on the connector.
GEN2 has the brown, brown/red and pink/black wires
Warthog
232
OKC, OK
Just to clarify, at the connector, the orange wire will be hot at all times and the black wire is the ground which is controlled by the relay.
The gray wire is the power feed for the VM and heater control lights.
**** Corrected incorrect intel from the wiring diagrams ****
Brogman
Warthog your help is greatly appreciated. Checked the connector for the relay and I do have power to a pink/blk stripe wire with the ignition switch on. There is a black/white stripe wire and 3 other black wires going into the connector. 2 of the black wires come together to the same connector to the relay. Funny thing the gage light worked some times I had to wiggle the wires and the gage didn't. I put in a new relay. It did click when ignition turned on. Now the gage still has no power to the gray wire that was connected to it but the orange wire to the light connector has power all the time. Another wiring harness I have to cut open and find the problem. I couldn't even come close to figuring this out with out the help and information from Steel soldiers. I am working on the front axle and drive line replacing ball joints/tie rod ends/bearings/seals/hubs/lockinghubs/rotors/brakes/lines etc. And this hopefully is the last electrical problem to be fixed for now.
cpf240
Free in Northern Idaho
Please re-read Warthogs post above yours. The orange wire is hot at all times and goes to the gauge, not the light. The black (not the white/gray) wire is the ground wire for the gauge, and is switched via the relay. The stock gauge is isolated from the rest of the dash, so does not get its ground connection via its mounting, as is common with many gauges. The relay provides the ground path when the key is on.
Warthog
232
OKC, OK
No need to cut open the wiring.
As cpf240 said the black (not the white) wire is a ground. You will not get a voltage reading from it. You can however see if it is providing a ground path. Energize the relay and use an ohm meter on the black (not the white) wire and a ground to see if the ohms go to zero.
Sounds like the ground wires (black wires on the relay connector) are not making good contact all the time.That is why when you wiggle them the light comes on.
Check the common ground point at the emergency brake pedal. See the picture in the link. You can check the ground wires by putting an ohm meter on the black wires and a clean ground.
http://www.steelsoldiers.com/showthread.php?120289-CUCV-Electrical-Ground-Locations
Warthog
232
OKC, OK
Okay I found where the confusion is. I was giving you bogus instructions.
The wiring diagrams are wrong. It is showing the ground wire for the voltmeter as being white. The true color is black (or brown , can't tell from the picture). It is the "other wire" in the two pin connector with the orange wire. (I have never had to work on this so I never looked at the diagrams).
The gray wire is the hot wire for the voltmeter light and will only be hot when the headlight switch is on.
Brogman
You gentleman are the best. I will try to digest this new information. I wired the light and gage exactly as I found them wired to the old gage and old gage light. The wires I wiggled where the ones to the light up in the dash. I didn't mess with the relay wires. All I did was check voltage at the relay plug and replaced the relay. The light did work with the light switch before I replaced the relay wired as shown, I guess the orange wire was wired wrong and the black ground wire wasn't grounding until I wiggled it. Don't know. Thanks for all the help.
