Voltage fluctuating to the high side. Help
Coalminer61
Ohio
My voltage stated bouncing from the green to red on the volt meter last night on the way to work. Lights and dash definitely getting brighter and then back to normal. Check with multimeter and voltage at batteries is jumping from 28.5 to 34.5 back and forth. Any ideas? Both alternators are new within the last couple years.
19,755
Started messing with it today and found a loose connection on the battery to battery cable. Repaired it and problem seems to be gone
Yes! Glad to hear it seems to be resolved!!
Especially since it was a loose connection...
