Fastfunco
- 0
- 6
- Mohave valley , Arizona
M925 A2 - everything brand new- military did a frame off - new cab - motor 8.3 turbo- trans - everything-
start up and volt gauge spikes
checked at batteries and im getting 37 volts
batteries brand new as well
Im pretty sure its voltage regulator- but figured I would ask?
while driving home- every once in a while lights were getting really bright - then in a few minutes- back to normal
It might be something incompatible after the restoration was finished- I found that the oil pressure gauge is for a different temp sender--
Any Ideas on the voltage problem???
