Voltmeter gauge not working
gestut
az
Has an expanded scale so it doesn't even come off the stop until 20 plus volts. Get to know this gauge. It is important.
Green go , Yellow or Red fix it. CAMO
I understand about the gauge readings , but i was assuming it would show even a little bit of movement on the needle at 12.6 v , thats all i was saying, but thanks for the input
Crapgame
340
Navarre, FL
He's probably hooked up to the other screw the one opposite the rubber plug
Thank you, that is part of my current gigs on the M1097A1, I put the ground lug on the metal retainer bolt.
Where does the main instrument cluster ground wire attach to?
Edit: The info above allowed me to correct the harness connection to my volt meter, but I am still trying to figure out where 57G attaches to.
Retiredwarhorses
4,541
Brentwood, Calif
