W/W vs WO/W
Rebelpride
Thomasville, NC
I was mowing around the deuces this weekend and noticed that the lawnmower fit further under the winch truck than it did under the no winch truck. Does one sit a bit higher than the other?
emmado22
147
Mid Hudson Valley NY
The winch adds about 450# to the very end of the front end, so it's going to sit a bit lower (maybe an 1 inch or so depending on the condition of your shocks)
1,331
decatur alabama
the winch trucks front bumper sits about 8" higher then the wo/w winch trucks. if you look at it the bumper is not dead infront of the frame with a winch it actually sits up higher
Jake0147
Panton, VT
Shocks don't hold it up, springs do. :wink: So I'd expect it to be a touch lower under the cab steps and such, however the frame extensions do raise the front bumper considerably.
tie6044
42
Blaine, MN
I just swapped a winch this past weekend, the winch truck uses a regular bumper flipped upside down and it does sit higher than a stock one. The stock bumper slides directly over the frame, the winch bumper with extensions sits out and higher.
hole
Alta Loma , Ca.
Brother Will noticed that last weekend while my Deuce was next to his. Mine is WO/W his W/W We measured them at the top of the wheel wells and his was 1 inch lower. Guess that extra 500 lbs makes a differance
steelandcanvas
85
Southwestern Idaho
Sorry, shocks don't do anything to hold the truck up, that's the job of the springs. Shocks dampen the spring's travel.
