W400 Ambulance
Bob H
159
Well I finally found my W400 Ambulance! I have to get er home yet.
It has an automatic trans though, Thought they all had 4speeds :cookoo:
360 with air under the hood, 727 tranny, Open knuckle dana 60 up front and a 70 in the rear
acetomatoco
Each small contract for the W400 had its own requirements.. so "all had automatic" would not be accurate... although the two I have seen around here were 360 with 727 and the two big Danas...and the rust.
Bob H
159
Had some time to look a few things over yesterday.
This thing has 4.88 gears :shock: :mrgreen: and a locker in the rear [thumbzup]
& I had that thing running 60 - 65 mph bringing it home :oops:
Have to buy wheels & tires. (as I posted in the "Coversations" forum)
Now that I know it has 4.88 gears. I think I'll end up with a set of 900-16's on it.
Was kinda leaning towards putting radials on it and keeping it duals.
900-16's are 36" tall and I haven't found any radials that are that tall & still fit on the duals.
sf38a1
NW Florida
RE: How about this?
I saw these type of ambulances when I was stationed at Lackland AFB, in 1975.After i got out in 79, I tried to fined them at surplus, but had no luck, I didi find one in 1988, but the owner removed the ambulance body and replaced it with a regular cab.I had never even seen an M866 until I was out of the AF. While station at TyndallAFB they used a J20 jeep ambulance w/winch, for inflight emergencies.I now own a M725,I always wanted a military ambulance eversince i was a kid.
Lifer
58
Elberton, GA, USA
Where those trucks special contract for like the air force or something as opposed to the M886?
The Dodge W400 is the civilian vehicle upon which the M880 series of military vehicles is based. The military ambulance is the M886, and was used by all branches of the armed forces. ("W400 ambulance" is a term used by "car people" who don't know any better. ;) )
Bob H
159
The M880 series trucks were based on the 1976 & 1977 Dodge W200
The M890 series trucks were based on the 1976 & 1977 Dodge D200
These Air Force W400 Ambulances were indeed different from the M893 / M886.
They started life at the same Dodge assembly line and Finshed at the same "Mark Body Co" here in Michigan as the M893/M886's.
The data tag on these AirForce Ambulances list them as "Truck Ambulance 4x4" and "Dodge Truck Model" as "W400"
These trucks did not have a M series designation.
FSN or ACVC # 2320-00-684-3772
Contract # DAAE07-77-C-4268
As for the rear door, at 59" x 41" by not real thick or very heavy.
It is too big for the Post office, and I believe too big for regular UPS, (can't seem to get their shipping estimator to work on my PC.)
need a way to get that door from Mid Michigan to Fargo ND.
edit:
photo added for comparison, the one on the left was originally Strata Blue
m376x6
Colorado
I just picked up a Dodge W400 contracted for the US Navy under contract
N 62472-78C-1609. The truck has USN registration number 71-02527. The truck is a 1978 4X4 with a 360 V8 and a NP445 manual transmission coupled to a NP203 transfer case. It has a Reading Utility bed. It was listed as "Truck Fire Fighting Aircraft Crash & Rescue". The W400 series trucks were rated at 1 1/2 Tons by Dodge, but that was accomplished by the additon of leaf springs and the rear and front axles are the same as on the W300 series. They came in several different models, of which mine is listed as Cab and Chassis based on the vin. The W400 also came in an ambulance series, and was not the 886 series. The vin should start out with W4 as opposed to W1,2, or 3.
Regards,
M376X6
m376x6
Colorado
I would love to see pictures of your W400!
I start my four day rotation at work early in the morning, 12 hour shifts. I'll get a chance to take some quick pics Monday. I'll post a couple then. Does your W400 also have a NP203 transfer case? If I understand the info correctly either 1978 or 1979 was the last of the 203's. The 360 in it is junk so I'm considering a nice 440 I have and also a NP205 exchange. Do you have any idea what years the W400's were built for the various branches? I'm kind of the opinion that they, along with the 880 and 890 series were rated a little above the components they were built with.
Regards,
M376X6
