I have a 2003 1045A2 with about 1200 miles on it. When I turn the ignition switch to run the position, my “wait” light won’t go out. Prior to this the Wait light would flash on and then off and the truck would start. It would stay lit for less than a second. When the weather is cool it has to crank hard to start so I had been wondering if this was going to be an issue so I have been kind of keeping an eye on it. Is the wait light somehow connected to the dimmer switch?
I have been having problems with the foot operated head light dimmer switch not working and I am going to replace is as soon as my new one arrives. The high beams won’t come on and the bright indicator light on the dash won’t light. The night before I had the wait light issue, I had been cycling through the head light and dash dimmer settings with the main light switch and the floor mounted dimmer switch, with the engine off. Could this possibly have anything to do with the Wait light issue? When I turn off the ignition after unsuccessfully trying to start the truck, there is an audible “clunk” sound from the engine starting system box under the dash. I am not sure if that is normal or not but it kind of sounds like a solenoid closing. Thanks in advance for any advice. and yes, I have searchd and I have RTFM....
