2deuce
- 147
- 63
- portland, oregon
I'm trying to understand this system better. I read through the TM. I have a truck with the resistor bypassed. It would seem that bypassing the big resistor would be a good idea, but thats another thread. What turns the wait light off? It wants to stay on with the truck running. If the module turns it off, where does it get its info? Being the resistor is bypassed I think the troubleshooting guide won't always apply. The wait light won't come on with the module removed. I put in a different module with the same result, the light stays on. The TM says not to leave the key in the on position over 2 minutes, so I was concerned that leaving it running may damage the glow plugs. I put a meter on a plug and it reads 12 volts, with the key on and the wait light on. Not waiting until the light goes out start the truck. A steady 12v continues to be supplied to the glow plugs for 30-40 seconds after the truck starts with the wait light still on. After that the power drops to zero at the glow plugs and the wait light goes out about 10 seconds after that. Any ideas what is causing this. Does it have to do with the resistor being bypassed? Thanks
