Wanted 939A1 series manual
BMS07
23
Janesville,WI
Im looking for the TM 9-2320-272-24-2. Its the one that has all about rebuilding the 250 cummins. I have a CD that has it. Just would like the paper manual. Thanks Brad
steelsoldiers
3,968
Charleston, WV
Check eBay. I bought a whole set of 939/A1/A2 manuals on there for around $50. I stuck them in big 3-ring binders and drag them with me when I go to work on my truck.
BMS07
23
Janesville,WI
Thanks Chris but I have checked on ebay with no luck. And Wayne the printer is not broke but would go broke printing off all the pages. Thanks Brad
cranetruck
75
Meadows of Dan, Virginia
Look for the TM 9 2320-272-34-1 also, it has good coverage on the Cummins engine service/rebuild....
PM me if interested, I don't refer to it very often.
papercu
31
Baxley, Ga.
Unless you have a motor pool crew working on the truck at the same time, there is no need to print all, just print the pages you are going to work on at that time, if you don't mess them up after working, save them in a three ring binder.
Use some heavier weight paper if you like. Wayne
