Wanted Parts for M880
Hotrod1340
Lena, wi
I am looking for a PS pump, brackets, pulley and maybe a steering box to convert my 880 to PS
Bob said i am looking for this "a 75-77 W200, W300, or W400 with powersteering"
Also needed:
Hood in good shape.
Anything needed to put a plow on including the plow.
Tailgate would also be useful.
Thank you all in advance.
I am located 30 miles North of Green Bay, Wi.
Post message here or call me 920.373.5902
thanks
Elwenil
40
Covington, VA
Actually you can use the power steering setup off any W series Dodge truck from '72-'93 as long as you swap all the related components over. '72-'74 use one style setup, '75-'77 use another and '79-'93 should all be the same. If you swap over the steering box from another style, you will need the pitman arm, drag link and possibly the steering arm off the same style. It's pretty easy to swap everything over if you have a donor truck to get all the matching parts off of and are not too concerned about originality.
maddawg308
734
Front Royal, VA
I am going to a junkyard shortly. Last time I was in this yard they had a nice '77 W-200 4x4 with a 318ci. It had some frame damage, so it couldn't be used on the road. I will see what parts I can pull off it for you.
Hotrod1340
Lena, wi
Hey, Mike i installed a steering box I got from the guy i bought the truck from, So i am only looking for the pump and the mounting hardware.
