dilligaf13
- 33
- 28
- south, florida
I picked up one of the Warn 18k winches a while back and have finally got some time to try to wire it up. In the pictures I took I can obviously figure out the power and ground. I just wanted to confirm a couple things.
The Overload Interrupt is the Generation 1 so it's the square box in the second picture
In the third picture, according to Warn the small wire next to the power goes to power and measures voltage as part of the OLI system. Where does it go to power, at the battery or in line by the winch?
In the third picture, what does the red wire that's split in two do and what do I need to do to fix it (is it missing something like an inline fuse or does it connect to something else)??
Thanks for the help
Thanks for the help
