Barrman
- 1,734
- 113
- Giddings, Texas
One of the perks of getting the correct M35 fuel filters compared to the WIX 3511 and 3512 filters is that supposedly the military ones are cleanable.
I am using a M35 secondary fuel filter set to filter my WMO. I have a little bit of water in one of the drums. I of course didn't know it was there until flow stopped through the filters. Both are now chocolate milk clogged. I was pumping with the first filters drain cracked and when water came out, I opened it up all the way, thinking that would keep the water off the filter. It didn't.
The filter housing had two of the open filter elements that I believe is the NOS military type. Compared to the steel mesh encased 86512 filters I picked up this morning at Carquest.
So, which one is "correct" and how do you clean them? I will clean the cans with Varsol or the modern day equivalent. What do I use on the filters?
I figure this will be good to know for the proverbial cold rainy night far from home when the filters on the truck clog up and I can't go more than 3 mph. Besides saving money on filters for my refueling operation at home.
Thanks.
Thanks.
