WATER in "sealed" LED turn signal!
rolling18
76
Portland, OR
how to get water out of upper amber portion of LED turn signal lens?
this area is sealed by a black epoxy from the back and unable to access w/o doing more damage.
i cant see where water would get in. there is about 1/2 inch water visible through lens.
(not the blackout section)
thanks!
rolling18
76
Portland, OR
I was afraid I would have to do that.. but dont see any other option.
As suggested, i drilled the smalles hole i had a bit 1/16 i think...
any way, drilled through the epoxy near the edge of the light hoping i didnt hit any circuits
it worked! a small drip came out so I sucked the rest out got about 2 mouth fulls of water!! (not nasty either)
now I can use a very small screw to plug the hole since it will likley happen again
thanks
