70deuce
- 121
- 43
- Franktown, CO
Ok guys, here is the deal after dropping the oil pan. Check out the pics. With the coolant system pressurized, the only place I am seeing water dripping out is around the rear main bearing. Even caught a drip in the air in the 2nd pic. The truck has been sitting for some time since last trouble shooting attempt. Water goes to lowest point in oil I think which may have it gathering around the rear main. Putting one of those small mechanics mirrors up over the crank and up by the liner I could see no water running out between the liner and the block or running down the block anywhere above the crank. Oil cooler???? Maybe got lucky or is something else??? Checked all other areas under the crank. Layed some paper down on the floor the length of the crank. The only drips are coming from the rear main area. Also ckecked the fluid sticking to the bottom edge of the #6 liner. Its all oil, no water. Aslo, one guy can take off that monster of an oil pan ok but you better get two to put it back on.
Phil
Phil
