Water Pump Gasket
Tinwoodsman
76
Comfort, Texas
Anyone know where I can find a gasket for a Multi Fuel water pump? I have tried Saturn, Erik's, Ebay and C&C. Thanks.
runk
65
Houston, TX
Yep, make your own. Gasket material from any autoparts store (I used the felpro blue stuff for cooling gaskets). I used "freezer paper" (plastic coated paper from the grocery store) to make a template, then cut out the gasket material with a sharp pair of scissors and a hobby (x-acto) knife. The freezer paper is great because its cheap and you can roughly cut it to size, then crease it over the part details (inner diameters, holes, etc) to get an exact template.
harleyrkc
Burton, MI
I'd tap out a gasket using the suggested felpro gasket material with a 2 oz. ball peen hammer. Or you might consider buying a larger sheet of gasket from some one like McMaster Carr, that way you'll always have gasket material on hand.
