Water pump to oil cooler pipe replacement
panzerjunky
san diego ca
Hello again Gents
I am in the process of replacing all the hoses and belts on My Deuce all going good thanks to the awsome set of hoses from Mr. Will wagner but....... The 2 inch OD steel pipe running from the water pump to the oil cooler looks good on the outside but is heavily pitted at the ends on the inside.
Question is there any localy available replacements for said pipe evenif the ends are to long it can be cut down.
Would 2in muffler pipe of same gauge work?
I did see a piece in rubber at napa it was an upper rad hose for something it would have to be cut down would that work.
If all else fails who might carry one commercialy?
Thanks Jerry
cranetruck
75
Meadows of Dan, Virginia
It has a part number, 10935616 or NSN 4710-00-133-8174. Check with Memphis.
I have a used one, but may not be much of an improvement over what you now have...
