tjmilitary
- 2
- 18
- Grant Park,IL
I am loking for somewhere to buy a master cylinder for my WC. Does anyone know where to get them?
My WC-51 has an M37 master cylinder on it and it works, but I'm replacing it with a proper WC part when I rebuild the brakes. The master cylinder on a 3/4 ton WC sits slightly at an angle and the reservoir on an M37 master cylinder can not be filled all the way when used in this application. The proper master cylinder's reservoir sits at an angle in relation to the actual cylinder so it's level and can be filled all the way.tractor what do you want for a core. really not sure what to do. Some people say an m37 wc will work but others say it wont. Will it or not?
You should contact Charles Talbert at M-Series re-build, even though M-37s are their thing, at the very LEAST he could most definitely point you in to the right place.tractor what do you want for a core. really not sure what to do. Some people say an m37 wc will work but others say it wont. Will it or not?
