Weapon Mount and Shelter lmtv
engele
Nagold / Germany
Hi,
i'm looking for a Shelter for my lmtv. But the Truck should not higher than 3,6-3,7m. i found only the s-280 Shelter which is very high. Did the army use a smaller Shelter too?
And is the weapon Ring from m900 Series the Same like lmtv weapon Ring?
best regards alex
bikeman
501
Ft. Bragg, NC
Hi,
Army bought "pre-made" shelter version. the M1079.
best regards alex
Not really. the LMTV weapons ring is integrated into the cab versus having a separate ring and mount system like previous versions. I'm not sure if the ring itself is the same as a M939 series truck.
tennmogger
542
Greenback, TN
Hi,
best regards alex
Alex, I just today set an S-318 on my LMTV. Total height is almost exactly 11 ft, 3.4 meters, just short of your max height.
I will take some pictures tomorrow if you are curious what it looks like.
Bob
engele
Nagold / Germany
Hi,
i use a belgian Radio Shelter which is about 2.5m Long and only 1,65m high. Little small. Today i put it on my lmtv, and it fits under the Cover, and i can sit behind the Shelter under the Cover. 
I will lock for a Gun Ring here in Germany and for a bigger US Shelter with only 2m high. If not i take a regular s-280.
Thanks a lot.
tennmogger
542
Greenback, TN
tennmogger
542
Greenback, TN
Engele, you have some fine looking hardware over there! I find a good accessory for a 'short' shelter is a rolling chair. Get in, sit down, and scoot around where you need to go in the shelter. Works well if desks and radios are involved.
Bob
