LastFbody
- 10
- 18
- Milwaukee WI
So I bypassed the glow plug resistor like has been outlined many times by other users. Just tried it with the original gp relay just to see what would happen, and maybe save a couple bucks if it worked. It seemed to work kind of at least. The glow plug relay and wait light kick on with the key as usual, and the truck starts right up with no drama. What has changed is the stock voltage gauge that used to read on the border between green and the upper red now reads in the mid green. The other thing that changed is the afterglow didn't engage at all, and it almost always did before in the garage, which is usually about 50 degrees.
2 questions that aren't mutually exclusive:
1. My garage was about 50 degrees ambient. The truck always used to run the afterglow 3-4 times at that temp. May have been running incorrect before due to electronic space magic and is now running correctly. My one truck is my only frame of reference, when is the afterglow supposed to engage normally?
2. Glow plug relay issue? Heard that sometimes after being hooked into the stock resistor system for however long that they won't get enough juice under straight 12v to kick on. Could it turn on for the primary glow cycle and not be able to turn on for the afterglow cycle?
Edit: According to this thread (specificly Antennaclimber's posts) https://www.steelsoldiers.com/showt...ystem-Dilemma-AntennaClimber-this-is-for-you-) the afterglow cycling on and off after startup that I've become familiar with is due to the gp card recieving more than 12.5v, and if it recieves 12.5v or less the afterglow is steady. Can anyone confirm this threads claims as accurate?
