Weld or Replace?
Gouldian
Goulds Hollow, Ohio
After crawling around in the mud I located the reason my brakes were inop. The hydro side of my air pack has a crack. I work as a pipefitter and I'm confident that one of the old guys could weld it up. is this a viable solution? Or should I just pony up the full paycheck to buy a new one? I know that brakes are not an area to skimp on, however we regularly weld pressure systems. Any advice would be helpful. Thank you in advance.
Jeepsinker
414
Dry Creek, Louisiana
If I were you I would try and find a rebuildable core and just rebuild it and install instead of buying a new one. I know pipe fitter welders are excellent welders, but bear in mind that that housing is cast, and cast can not be reliably welded. Not when it comes to a brake system anyway.
swbradley1
Modertator
1,656
Dayton, OH
Actually the best thing is that you asked first instead of us reading about your horrible crash from brake failure in the papers.
:p [thumbzup]
FloridaAKM
392
Gainesville, Florida
From this posting, I gather that trying to repair brake system parts is a bad idea & replacing these parts is nothing short of doing the right thing to prevent any small or large accidents from happening. Thanks, I'll look for a dual line brake system truck!
