TxFireDeuce
- 1
- 18
- San Antonio Texas
Has any one setup a welder off is the alt. on the multi fuel I did a search no luck
The welding process I used in the video isn't quite as versatile as the weldernator...but it is almost free. Hard to beat that!Has any one setup a welder off is the alt. on the multi fuel I did a search no luck
I typically use the jumper cable stick welding only as an emergency trail repair; I've never burned through more than a couple of electrodes on any single project. The batteries hold up fine for those shorter jobs. Using this method of welding uses about the same amperage as a starter turning over a large diesel engine...so the batteries are capable of welding for about as long as they would be able to turn an engine over. Good healthy ones will give you a few minutes of welding, old worn out ones will give you under a minute.Do you have any issues with battery life welding with jumper cables
