Welding rear ends?
Parker2
Plant City, Florida
I was thinking of putting in Detroit lockers in both rear ends, but then I thought why not weld both rears and put lock out hubs on them. Would this be better than lockers? Also would this add more wear to everything or when unlocked would I still have the benefit of less wear because of the lock out hubs? How would this do both off and on road? Please feel free to talk down to me as I am not too familiar with the differentials.:)
Thanks.
m16ty
211
Dickson,TN
If you had lockout hubs on all the axles your truck wouldn't move with the hubs unlocked. The only way the truck could travel is to just unlock one side. This would make cornering a little unstable and would make the truck pull to one side when going down the road. Guess you could alternate the pulling side on the tandems but it still wouldn't handle right. I think it's a bad idea.
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
I had been thinking of doing this to one axle, so I could have a regular diff(or two counting the front) for on road, and a locked one offroad. Haven't thought too hard about it though.
m16ty
211
Dickson,TN
Gimpy, I'm sure it would work fine with just one axle welded and lockouts on said axle. Wonder how much it would help in mud with the other axle open though.
gimpyrobb
27,785
750
Cincy Ohio
If I posted every thought I had about what I might do to a truck, you guys might have to change my screen name to "DR. SEUSS"!
mudguppy
15
duncan, sc
i would go w/ the ouverson lockers, though. they can be had for the same price as Detroits and are made of a little better material.
IHASFIP
TEXAS
I figure it would be really hard on the last jack shaft ( or whatever you want to call it), if you welded both set of spider gears. I would fork out the money for Ouverson lockers if I were to lock the rear of mine. I would really like powersteering and an ARB for the front. Or hell 3 ARBS would be awesome, and expensive... :cry:
D
