KallyLC
- 144
- 33
- Atherstone, UK
I need to do some welding on my M1008. On my other vehicles, I normally just disconnect the negative connection and make sure the ground is good before I weld. No problems doing it that way. But that's one battery on a 12v system. What do you do with the two batteries on a 24v system?
'do you disconnect the battery before welding' is a question as old as time itself, and one people seem to have a lot of strong opinions about, so I'm expecting the full range of answers here. I know there's not much in the way of electronics on these trucks, but I would rather ask the stupid question than risk damaging something.
So the question is, if you disconnect the batteries before welding, which connections do you remove? Just the negative on one battery? Both of the negatives?
