Were to find M416 tires?
Dolphin_Shooter
Junction City Ohio
a buddy picked up a M416 Trailer. The tires are dry rotted to **** and back
he's wanting to know if anyone makes civi tires that might work better at Highway speed? If not dose anyone have a source for original Military tires?
mutt_kahuna
M151 country,Nevada
tires for M416
Hi...the stock size tires for an M416 are 700-16's...he can get them from Lucas tire or summit racing both have locations in OH .....close civi equiv size is 215-85-16
maddawg308
734
Front Royal, VA
Don't hold your breath waiting for a lot of surplus 7.00x16 tires to come up on GL. They haven't been available in the DoD system for many years.
Lex_Ordo
Long Island, NY
Pick out either the NDCC, or NDT tread type of 700-16 Firestone tires made by Coker or Universal. They are good repro tires that will give your trailer the military look you want, and are made new with todays materials. I have them on my 1/4 Ton M101 CDN2, and they work great!
2ndchance
Glendale, AZ
Can you use civilian equiv tires on the orginal M416 rims? I asked a guy at Discount Tire and he said, no. Reason:
1. The rivets on the rim can cause leaks when not using a tube.
2. Using a tube on a civilian tubeless tire causes a lot of friction and heat, causing the tube to fail.
So, how are you guys using civilian tires on original M416 Rims?
