Were to find out more information
Monty
Raymond Wisconsin
I just purchased a 1958 5ton, gas engine with a 4 speed. Were can I locate more information about it? Are the gas engines worth keeping or should (could) it be converted over to diesel?
Thanks for any and all help anyone can give.
Ser# M543364 Date Dec. 58 this is what I was told was on the data plate.
Chad.
papercu
31
Baxley, Ga.
truck
Well that depend on what you plan to do with it, work or fun?
If the gas was running good and you don't mind 4 mpg (if you are lucky) I would keep it.
The diesel made for that truck is only a little better at 5 mpg but it will then sound like a real truck. :D Wayne
acetomatoco
RE: truck
If your truck only has a 4 speed tranny you are not dealing with original equipment. Your data plate indicates it is an early M54, built with a Continental 6602 gas engine and a 5 speed Spicer transmission and a two speed transfer case... There is more information available for that truck than you could read in a lifetime... Start with all the Manuals for the G744 ...you can buy them at Portrayal Press... The series TM 9-2320-211 manuals are what you need to be studying.. All the parts you need are just down the road in Akron OH... Sam Winer Motors...
Monty
Raymond Wisconsin
RE: truck
Thanks for the information, I have yet to get it home and I'm going off what information was in the ad, once it's here I'll verifiy the information is correct I'll post again.
1,127
RE: truck
I think it goes without saying we want to see some pics of your truck!!
:nopics:
