Wet sanding new paint?
Stalwart
33
Redmond, WA
Not on OD but with conventional paint both acrylic enamel and laquer. If you have to do it early a bit of liquid soap works well as a lubricant in addition to the water. Rinse well when done, and repaint with a wetter coat of paint.
I think you'll wind up with a semi-gloss if you don't paint it again.
waayfast
106
Lake Fork,Idaho
Also remember there is a critical time with Synthetic Enamels--known as re-coatability. If you have JUST painted-it will take another coat--or if it has cured for a good while(like a week or better) it will take a another coat. BUT in between it will lift like you poured paint remover on it.Check your label, or talk to the dealer/manufacturer to find this out for sure.
Most likely if you are sanding it , it is past the critical stage-- but it doesn't hurt to be aware so you don't have a BIG problem.
And yes, as stated above, after sanding off the pimples ,bumps ,runs and orange peel you will have to put another coat of OD or you will have a "shiny" look.
Hope this helps, Jim
rneely
Casco, MI
Are you saying flat paint will become semi gloss because it was wet sanded? Kind of like polishing it? How many recoats are usually needed?
