What’s the max continuous load a 005 will carry. I saw a guy run one up to 49kw
Philratcliffe
9
Florida
I have a few 005 questions
There was a post here on as where a generator repair guy picked up a poor running 005!that had been run one hour a month for a year or so with no load so it was wet stacked badly. He ran it and kept increasing the load til he got to 30 kw. Ran it like that for about two hours then kept loading it up to see what it would pull and it went to 49.8 kw.
What is the max load you can run one of the 005s to continuously without damaging the unit?
How many hours between oil changes?
Are all white engines in the 005s 2 valve or 4 valve engines?
Thanks in advance for any info guys.
flydude92
Waterville, Ohio
I would be afraid to find out.
It's been a couple years since I tried this but if I remember the TM says it will go into overload after about 8 minutes.
I ran mine at 36,000 watts for about 8 minutes when it shut down with an overload light. I wanted to see if it would shut down and I only
was going to run it about 10 minutes before I shut it down.
