What’s this part from?
319cssb
221
Easley SC
Does anyone know where this parts belongs ?
I found two- on either side of the frame rail .
Update: I figured out what the two strips are, they are holding the bottom plate under the radiator to the frame.
Migginsbros
7,623
Berlin-Germany
In this area there is a connected part mounted on the inside of the support frame. I was out at the SEE but can´t see what it is. Nor for what it´s used. In this moment I can only feel is´s rectangular,big as a package of cigarets. Mounted with one bolt. Will try to take a pic.
319cssb
221
Easley SC
Today I tried to see what this box connects to, but I can't find the corresponding connector. Anyone know what the box is used for?
319cssb
221
Easley SC
Not interested in helping someone that won’t read the manuals.
As I said before already, I have an IPhone 7 and for the most part I have spotty reception at best. Trying to find things on a tiny screen using a pdf and no internet connection is a challenge.
But thanks for the reply anyway
20,760
Looks like you have a nice patch of woods to play in down there in Easley.
Guyfang
27,149
Burgkunstadt, Germany
The bolt right above your hand. That is the one Chris said held a box in the inside of the frame. Take a look or simply remove it. It could be the box listed in the -24P, PDF page # 318, Figure 76. item 7. But I am not sure. If the box is there and you can find a part # it would be easier to find.
319cssb
221
Easley SC
Guy , I think that’s what it is. At least that’s what it looks like on my tiny screen. Part number # 1039-07134-01 resistor network film. What is it for?
20,760
I can’t find the other side to the connector. I tried hooking it up already.
Unless I am misunderstanding, the "other side" of the STC / ICE ( Simplified Test Equipment for Internal Combustion Engines) connection is a series of pins that come from a wire that ICE box. Picture below:
